[Qgis-user] QGIS install fail on Ubuntu 12.04
    Lee
    muellerl at gmail.com
    Mon Mar 18 11:57:20 PDT 2013
In general, the error messages are generated upon launch of QGIS. I cannot
even get to a point where I have the option of installing plugins. There is
no option to "fetch python plugins."
Unfortunately the permission change has produced no change in results.
All the best,
Lee
ISA Certified Arborist MI-4148A
Registered Forester #46043
On Mon, Mar 18, 2013 at 2:52 PM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Am 18.03.2013 19:47, schrieb Lee:
>  No dice. Plus, I'd think that "sudo qgis" might solve that issue, but it
>> doesn't.
> I just tried to install plugins, got the error message, did the sudo (with
> -R), and it went through.
>> In either case, near the bottom of the second link is this statement:
>> "OP said they couldn't install 90% of plugins - I found, after upgrade to
>> Ubuntu 12.04, that only the core plugins (C++?) were available, to get all
>> the python plug-ins as well, you need to install the package python-qgis
>> as
>> well."
>> This is what I attempted before this whole odyssey began. "sudo apt-get
>> install python-qgis." Unfortunately, this generates the following unmet
>> dependency errors:
>> The following packages have unmet dependencies:
>>   python-qgis : Depends: python-qt4 (>= 4.1.0) but it is not going to be
>> installed
>>                 Depends: python-qgis-common (= 1.8.0-1~precise3) but
>> 1.9.0+git20130316+5d42734~**precise1 is to be installed
>> E: Unable to correct problems, you have held broken packages.
> Looks like the python-qgis is to be installed from the wrong place. And
> python-qt4 seems somehow wrong also.
> Greetings,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/04410bc5/attachment.html>
