[Qgis-user] QGIS install fail on Ubuntu 12.04
Lee
muellerl at gmail.com
Mon Mar 18 13:03:22 PDT 2013
On attempting to manually install qt4 through the software center, the
following error is generated:
Package dependencies cannot be resolved
This error could be caused by required additional software packages which
are missing or not installable. Furthermore there could be a conflict
between software packages which are not allowed to be installed at the same
time.
The following packages have unmet dependencies:
python-qt4: Depends: python (< 2.8) but 2.7.3-0ubuntu2 is to be installed
Depends: libgcc1 (>= 1:4.1.1) but 1:4.6.3-1ubuntu5 is to be
installed
Depends: libqt4-dbus (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
to be installed
Depends: libqt4-declarative (>= 4:4.8.0-1~) but
4:4.8.1-0ubuntu4.2 is to be installed
Depends: libqt4-designer (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4
is to be installed
Depends: libqt4-help (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4 is to
be installed
Depends: libqt4-network (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2
is to be installed
Depends: libqt4-script (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2
is to be installed
Depends: libqt4-scripttools (>= 4:4.8.0-1~) but
4:4.8.1-0ubuntu4 is to be installed
Depends: libqt4-svg (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
to be installed
Depends: libqt4-test (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4 is to
be installed
Depends: libqt4-xml (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
to be installed
Depends: libqt4-xmlpatterns (>= 4:4.8.0-1~) but
Depends: libqtcore4 (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is
to be installed
Depends: libqtgui4 (>= 4:4.8.0-1~) but 4:4.8.1-0ubuntu4.2 is to
be installed
Depends: sip-api-8.1 but it is a virtual package
All the best,
Lee
ISA Certified Arborist MI-4148A
Registered Forester #46043
On Mon, Mar 18, 2013 at 3:37 PM, Andre Joost <andre+joost at nurfuerspam.de>wrote:
> Am 18.03.2013 19:57, schrieb Lee:
> In general, the error messages are generated upon launch of QGIS. I cannot
>> even get to a point where I have the option of installing plugins. There
>> is
>> no option to "fetch python plugins."
> Yes, this is a follow.up to the missing python package.
> Try this:
> Open Ubuntu software center
> Edit -> Software package sources
> "Other Software" tab
> There should be two entries for ubuntugis-unstable (and nothing from
> ubuntugis-stable)
> close the window
> click on "AllSoftware", and enter qt4 in the search field
> You should have installed python-qt4 4.9.1-2ubuntu1
> If not, you should do it manually.
> click on the dropdown box next to "All Software", and select
> ubuntugis-unstable. You should have QGIS, and a note that 177 files are
> hidden. Click on that link. You should get a list of all packages from
> ubuntugis, including python-qgis. Clicking on that, you should get
> information on the version python-qgis 1.8.0-1~precise3, and if it is
> installed or not.
> Greetings,
> André Joost
> ______________________________**_________________
> Qgis-user mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/da6130ea/attachment.html>
