[Qgis-user] Colouring lines
Andreas Neumann
a.neumann at carto.net
Fri Mar 22 00:53:16 PDT 2013
Hi Brett,
Styling is normally not saved in the shapefile itself. You would create
rules based on the attribute data of your data set. There are simpler
rules (e.g. categorization based on a single attribute) and more complex
rules involving several attributes and more complex logic.
In your case you would define an attribute at your four lines that
represents the values you want to base your color scheme on and then use
one of the above.
This is really basic GIS stuff and you can find this in the QGIS
manual:
http://docs.qgis.org/html/en/docs/user_manual/working_with_vector/vector_properties.html
It is a basic GIS principle that you store properties of GIS features
and not how they are represented. Representations are built from rules.
You can then clearly separate the content (geometry and other
properties) from how it is represented and you can do several
representations out of the same data.
Hope this helps.
Good luck,
Andreas
On Fri, 22 Mar 2013 14:51:03 +0800, Brett Adams wrote:
> Hi Folks.
> I have 4 separate lines in one shp file. Can I colour them each
> differently and give them each a different pen style? Will these
> characteristics them be saved when into the shp file?
> Thanks in advance.
> BRETT ADAMS
> SPINIFEX GEOPHYSICS
> 0438 861 974
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
