[Qgis-user] Text Size in WMS maps
Andreas Neumann
a.neumann at carto.net
Fri Mar 22 05:16:23 PDT 2013
What server is the WMS? Many servers support the DPI parameter nowadays
(not in the OGC standard - but most servers implement them). I know that
both UMN Mapserver and QGIS server support the DPI parameter.
Would be nice if the QGIS WMS client would support it as well - esp.
when printing/exporting the WMS.
Andreas
Am 22.03.2013 12:38, schrieb magerlin:
> Hi
> I use a cadastral map from a wms server. The wms map includes some text on
> each parcel.
> The text size is fine both on map canvas and in the map composer window.
> But when I save as either pdf or jpeg from the print composer the font size
> in the resulting file is dependent on how many dpi I save in.
> Only when saving in screen resolution I get text in a readable size while
> saving in a more normal resolution of 300 dpi gives text so small that you
> can't read it.
> Anything to do about that?
> Or is it simply wrong to deliver text as a part of a WMS map?
> Regards Morten
> Qgis 1.8.0 Stand alone installer in Win7 64 bit
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Text-Size-in-WMS-maps-tp5042320.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
