[Qgis-user] Text Size in WMS maps
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Fri Mar 22 05:20:00 PDT 2013
I think QGIS supports Mapserver, Geoserver and QGIS Server syntax:
QGIS wms request (snippet from apache log file):
/wms/avwms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=593935.2762915793573484,218157.3791828494577203,630296.8752945793094113,248210.9839420588396024&CRS=EPSG:21781&WIDTH=1003&HEIGHT=829&LAYERS=AVWMS_farbig&STYLES=&FORMAT=image/jpeg&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96
DPI -> QGIS Server
MAP_RESOLUTION -> Mapserver
FORMAT_OPTIONS -> Geoserver
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im
> Auftrag von Andreas Neumann
> Gesendet: Freitag, 22. März 2013 13:16
> An: qgis-user at lists.osgeo.org
> Betreff: Re: [Qgis-user] Text Size in WMS maps
> What server is the WMS? Many servers support the DPI parameter nowadays (not in
> the OGC standard - but most servers implement them). I know that both UMN
> Mapserver and QGIS server support the DPI parameter.
> Would be nice if the QGIS WMS client would support it as well - esp.
> when printing/exporting the WMS.
> Andreas
> Am 22.03.2013 12:38, schrieb magerlin:
> > Hi
> > I use a cadastral map from a wms server. The wms map includes some
> > text on each parcel.
> > The text size is fine both on map canvas and in the map composer window.
> > But when I save as either pdf or jpeg from the print composer the font
> > size in the resulting file is dependent on how many dpi I save in.
> > Only when saving in screen resolution I get text in a readable size
> > while saving in a more normal resolution of 300 dpi gives text so
> > small that you can't read it.
> > Anything to do about that?
> > Or is it simply wrong to deliver text as a part of a WMS map?
> > Regards Morten
> > Qgis 1.8.0 Stand alone installer in Win7 64 bit
> > View this message in context:
> > http://osgeo-org.1560.n6.nabble.com/Text-Size-in-WMS-maps-tp5042320.ht
> > ml Sent from the Quantum GIS - User mailing list archive at
> > Nabble.com.
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
