[Qgis-user] manually change FID/OID
José Pedro Santos
zpsantos1 at hotmail.com
Tue Mar 26 09:07:09 PDT 2013
Hi Christian,
Why you don't create a new column with the ID values that you want? If you want to edit some columns or rows you can use the Field Calculator.
Best Regards,
José Santos
Date: Tue, 26 Mar 2013 16:59:08 +0100
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] manually change FID/OID
i have the following problem: If i export a postgis db with qgis it mixes up the rows. On the first position in the attribute table is a value with id 2400 but should be 0 or 1
e.g.
id objectname
0 | 2400 | name 2400 ...
1 | 828 | name 828 ...
When i inspect the database, everything seems to be ok, as the line with id =1 shows up on the top position and id is set as primary key.
Has anybody an idea how i can get my table back in the right order or how to manually update the FID/OID with my id values?
I need that for an geotools importer which reads the FID and i cant change the import parameters.
Thanks christian
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130326/59f21bf2/attachment.html>
