[Qgis-user] QGIS web client on centos
Jan Koopmann
jan_koopmann at web.de
Wed Mar 27 05:59:52 PDT 2013
I renamed the GlobalOptions.js before.
Looking at the console it gives me the following error:
TypeError: OpenLayers.Format.OWSCommon is not a constructor
http://localhost/qgis-web-client/site/libs/openlayers/OpenLayers.js
Line 967:
var root=data.documentElement;var
exceptionInfo={exceptionReport:null};if(root){this.readChildNodes(data,exceptionInfo);if(exceptionInfo.exceptionReport===null){exceptionInfo=new
OpenLayers.Format.OWSCommon().read(data);}}
Do you know anything about that?
Greetings,
Jan!
2013/3/27 Andreas Neumann [via OSGeo.org] <
ml-node+s1560n5043274h1 at n6.nabble.com>
> Hi Jan,
> Do you see any Javascript error messages in the Javascript Console of
> your browser?
> Did you rename the GlobalOptions.js.template to GlobalOptions.js ?
> Andreas
> On Wed, 27 Mar 2013 05:39:14 -0700 (PDT), Jan Koopmann wrote:
> > Hello!
> > Showing the layers as a WMS in QGIS 1.8.0 is working now.
> > A restart was good.
> > Because of the GlobalOptions.js-settings, I misspelled that in the
> > post.
> > Sorry.
> > Correctly the ServerAndCGI-var was set to "/qgis/qgis_mapserv.fcgi".
> > The ScripAlias in the qgis_mapserver.conf is pointing to the right
> > dir.
> > I worked with the Firebug-Extension in Firefox.
> > Following the GetCapabilities-request shown in the network-tab is
> > working.
> > The shown answer in the answer-tab is the same as running it
> > manually.
> > I am trying to publish a link to the server this afternoon.
> > If you have any more suggestions before, I woukd be very welcome.
> > Greetings,
> > Jan!
> > View this message in context:
> http://osgeo-org.1560.n6.nabble.com/QGIS-web-client-on-centos-tp5043049p5043273.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email] <http://user/SendEmail.jtp?type=node&node=5043274&i=0>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5043274&i=1>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/QGIS-web-client-on-centos-tp5043049p5043274.html
> To unsubscribe from QGIS web client on centos, click here<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5043049&code=amFuX2tvb3BtYW5uQHdlYi5kZXw1MDQzMDQ5fDE2Mjg2ODEwMjY=>
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.n6.nabble.com/QGIS-web-client-on-centos-tp5043049p5043280.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130327/eaefb91e/attachment.html>
