[Qgis-user] Problem with qgis web client on ubuntu 12.04LTS
Andreas Neumann
a.neumann at carto.net
Thu Mar 28 10:23:13 PDT 2013
In js/GlobalOptions.js look for useGetProjectSettings or something similar and set it to false. You are probably using QGis 1.8 which does not support the GetProjectSettings command.
Andreas
Sylvie Perdriel <sperdriel at cairn-dev.fr> schrieb:
>Hello,
>I have just installed qgis web server and qgis web client on an ubuntu
>12.04 LTS computer. The QGIS server seems OK : GetCapabilities on a
>given project gives correct answer, GetMap draws a map on the web
>browser.
>If I run qgis web client helloworld, the "Loading map" is showned and
>nothing append. Using firebug, I could see that the problem comes from
>the GetProjectSettings (WMS version 1.3.0) : map server gives the
>answer
>"Operation GetProjectSettings not supported"
>Did somebody had already this issue and had an answer ?
>Thank's
>Sylvie
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130328/96ad27bb/attachment.html>
