[Qgis-user] Problem with qgis web client on ubuntu 12.04LTS
Sylvie Perdriel
sperdriel at cairn-dev.fr
Thu Mar 28 11:11:53 PDT 2013
Thank You Adreas,
It works fine now. Sorry to have missed this feature !
Sylvie
signature email
Le 28/03/2013 18:23, Andreas Neumann a écrit :
> Hi,
> In js/GlobalOptions.js look for useGetProjectSettings or something
> similar and set it to false. You are probably using QGis 1.8 which
> does not support the GetProjectSettings command.
> Andreas
> Sylvie Perdriel <sperdriel at cairn-dev.fr> schrieb:
> Hello,
> I have just installed qgis web server and qgis web client on an ubuntu
> 12.04 LTS computer. The QGIS server seems OK : GetCapabilities on a
> given project gives correct answer, GetMap draws a map on the web browser.
> If I run qgis web client helloworld, the "Loading map" is showned and
> nothing append. Using firebug, I could see that the problem comes from
> the GetProjectSettings (WMS version 1.3.0) : map server gives the answer
> "Operation GetProjectSettings not supported"
> Did somebody had already this issue and had an answer ?
> Thank's
> Sylvie
> Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail
> gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130328/6eee77b8/attachment.html>
