[Qgis-user] Use of $length
Patrice Vetsel
patrice at kagou.fr
Thu Mar 28 13:03:17 PDT 2013
I wan't to add the length of a line as label in a shape file layer.
I use the $length but when I use the tool to measure I don't have the same values.
I'v found on the net that may be I must use a special projection (here I'm using EPSG:4326)
It's seem's complicated, may be it's missing feature to add a "metric length" in label tool ? Or may be there is a trick ?
Thanks
Regards
Patrice Vetsel
