[Qgis-user] Field Calculator/Python Plugins
Alexandre Neto
senhor.neto at gmail.com
Fri Nov 1 07:19:28 PDT 2013
Hello Deon,
For Spatialite you can check this:
http://www.gaia-gis.it/spatialite-3.0.0-BETA/spatialite-cookbook/index.html#common
For Postgis, here is a good place to start:
http://workshops.boundlessgeo.com/postgis-intro/
To use QGIS to read Postgis and Spatialite, in the users manual, see this
links:
http://www.qgis.org/en/docs/user_manual/working_with_vector/supported_data.html#postgis-layers
http://www.qgis.org/en/docs/user_manual/working_with_vector/supported_data.html#spatialite-layers
http://www.qgis.org/en/docs/user_manual/plugins/plugins_db_manager.html
Hope this helps,
Alexandre
On Fri, Nov 1, 2013 at 4:32 AM, Pretorius Deon - Lieutenant Colonel <
PretoriusDeon at saps.gov.za> wrote:
> Hi Alexandre,****
> **1. **Thanks a lot for the info as I am new to QGIS, I will try it
> out.****
> **2. **Please tell me where can I learn more about Postgis and
> Spatialite as well as on how to use SQL and as to what phrases to use, and
> how can I learn more about it.****
> With Respect,****
> Deon****
> *From:* Alexandre Neto [mailto:senhor.neto at gmail.com]
> *Sent:* 31 October 2013 01:23 PM
> *To:* Pretorius Deon - Lieutenant Colonel
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Field Calculator/Python Plugins****
> Hello Pretorius,****
> Both field calculator and Python calculator, allows one to calculate
> values of columns, but does not affect the number of rows. What you need is
> to somehow group (sum, mean, etc...) field values by a certain column
> common value.****
> For that purpose I believe that Group Stats Plugin [1] is what you need.**
> Also If you are going to do lot of this kind of analysis, I would advice
> you to put your data in Postgis or Spatialite so you can run SQL queries.
> [1] http://plugins.qgis.org/plugins/GroupStats/****
> Hope this helped,****
> Alexandre Neto****
> On Thu, Oct 31, 2013 at 7:43 AM, Pretorius Deon - Lieutenant Colonel <
> PretoriusDeon at saps.gov.za> wrote:****
> Hi,****
> 1. Where can I learn more about on how to use the Field calculator
> as well as the Python Plugins as Iam new to this.****
> 2. I need to determine the unemployment rate for each district.
> There are over 10 000 small_place_codes and just over 1000 district. The
> majority of the small places overlaps with districts so I did an
> intersection for the two layers. An example of the results are as follows:
> 3. How can I now calculate what the average percentage are per
> Small_Place_Code and also what the results will be for each district?****
> Small_Place_Code****
> Districk_Name****
> Small_Place_Areakm2****
> District_AreaKM2****
> Unemployment_Rate%****
> *1112*****
> *Hamilton*****
> *0.0254*****
> *2.1753*****
> *6.21*****
> 1113****
> Hamilton****
> 0.1254****
> 2.1753****
> 4.25****
> *1114*****
> *Hamilton*****
> *2.0245*****
> *2.1753*****
> *21.21*****
> *1112*****
> *Queens*****
> *0.0045*****
> *4.4316*****
> *6.21*****
> *1114*****
> *Queens*****
> *0.215*****
> *4.4316*****
> *21.21*****
> 3333****
> Queens****
> 0.2121****
> 4.4316****
> 4.35****
> 3333****
> Queens****
> 4.000****
> 4.4316****
> 5.69****
> Regards****
> Deon****
> Qgis-user mailing list
> http://lists.osgeo.org/mailman/listinfo/qgis-user****
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131101/3c8439ad/attachment.html>
