[Qgis-user] Processing: how to autoload script results?
Alexander Bruy
alexander.bruy at gmail.com
Mon Nov 4 07:24:30 PST 2013
Hi Giovanni,
you don't need to load results manually, if you created script. Processing will
handle this for you. Manual loading only necessary when you work in Python
console.
2013/11/4 G. Allegri <giohappy at gmail.com>:
> I'm writing a model where my final script outputs the global result. I would
> like it to be loaded at the end of the process but AFAICS runalg only writes
> the output to the tmp library without loading it.
> I thought processing.load() was needed (and should be used only) from the
> console...
> giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
> Qgis-user mailing list
Alexander Bruy
