[Qgis-user] Processing: how to autoload script results?
G. Allegri
giohappy at gmail.com
Mon Nov 4 07:58:20 PST 2013
Hy Alexander,
that's what I thought... but it daoens't happen. I'll do some more tests
2013/11/4 Alexander Bruy <alexander.bruy at gmail.com>
> Hi Giovanni,
> you don't need to load results manually, if you created script. Processing
> will
> handle this for you. Manual loading only necessary when you work in Python
> console.
> 2013/11/4 G. Allegri <giohappy at gmail.com>:
> > I'm writing a model where my final script outputs the global result. I
> would
> > like it to be loaded at the end of the process but AFAICS runalg only
> writes
> > the output to the tmp library without loading it.
> > I thought processing.load() was needed (and should be used only) from the
> > console...
> > giovanni
> > Giovanni Allegri
> > http://about.me/giovanniallegri
> > blog: http://blog.spaziogis.it
> > GEO+ geomatica in Italia http://bit.ly/GEOplus
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexander Bruy
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131104/61a367c6/attachment.html>
