[Qgis-user] Overview map window tracking
Richard Duivenvoorde
rdmailings at duif.net
Wed Nov 6 06:59:05 PST 2013
On 06-11-13 15:34, Zoltan Szecsei wrote:
> Hi,
> I'm using 2.0.1.
> Is there a way to open a small map window that can be zoomed to your
> projects AOI.
> Then, as you zoom around your working map window, a rectangle box can be
> shown in the above window, giving you some perspective of where you are
> currently working.
Hi Zoltan,
yep, that is called 'overview' :-)
if you do see it, make it appear via: View/Panels/Overview
After loading one of your reference layers in QGIS, add it to the
overview via right-mouse on layer in Legend, and then 'Show in overview'.
That layer will be shown in the overview, with a red box for the current
map extent.
HTH
Regards,
