[Qgis-user] Desktop: Convert GRID to ASC bug?
Jess Clark mapperjess at gmail.com
Wed Nov 6 14:54:43 PST 2013
Perfect; thanks for the confirmation.
On Wed, Nov 6, 2013 at 3:45 PM, Alex Mandel <tech_dev at wildintellect.com>wrote:
> On 11/06/2013 01:18 PM, Jess Clark wrote:
> > Wondering if this is a bug in QGIS desktop ...
> > Trying to convert from ArcGRID to ASC using Raster | Conversion |
> > Translate. I select the ADF file from the GRID as an input, change the
> file
> > time for the output to ASC, choose my target SRS, and then check out the
> > GDAL code before running the conversion.
> > Everytime, the software ignores my selected output type and uses the
> > GeoTIFF conversion engine instead. I have to manually edit the code to
> use
> > AAIGrid switch instead, despite my choice through the GUI.
> > Is this documented as a bug? Am I understanding this correctly?[image:
> > Inline image 1]
> Known bug, you have to manually override the command in the advanced
> bottom box with the correct output format.
> http://osgeo-org.1560.x6.nabble.com/Re-Qgis-user-Format-conversion-QGIS-2-0-td5078135.html
> Thanks,
> Alex
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131106/8b8ea60c/attachment.html>
