[Qgis-user] Desktop: Convert GRID to ASC bug?
Alex Mandel
tech_dev at wildintellect.com
Wed Nov 6 14:45:57 PST 2013
On 11/06/2013 01:18 PM, Jess Clark wrote:
> Wondering if this is a bug in QGIS desktop ...
> Trying to convert from ArcGRID to ASC using Raster | Conversion |
> Translate. I select the ADF file from the GRID as an input, change the file
> time for the output to ASC, choose my target SRS, and then check out the
> GDAL code before running the conversion.
> Everytime, the software ignores my selected output type and uses the
> GeoTIFF conversion engine instead. I have to manually edit the code to use
> AAIGrid switch instead, despite my choice through the GUI.
> Is this documented as a bug? Am I understanding this correctly?[image:
> Inline image 1]
Known bug, you have to manually override the command in the advanced
bottom box with the correct output format.
http://osgeo-org.1560.x6.nabble.com/Re-Qgis-user-Format-conversion-QGIS-2-0-td5078135.html
Thanks,
Alex
