[Qgis-user] Desktop: Convert GRID to ASC bug?
Goyo goyodiaz at gmail.com
Wed Nov 6 14:45:50 PST 2013
In the file selection dialog, select also the file type. This tells the
translate tool which output format to use.
Goyo
2013/11/6 Jess Clark <mapperjess at gmail.com>
> Wondering if this is a bug in QGIS desktop ...
> Trying to convert from ArcGRID to ASC using Raster | Conversion |
> Translate. I select the ADF file from the GRID as an input, change the file
> time for the output to ASC, choose my target SRS, and then check out the
> GDAL code before running the conversion.
> Everytime, the software ignores my selected output type and uses the
> GeoTIFF conversion engine instead. I have to manually edit the code to use
> AAIGrid switch instead, despite my choice through the GUI.
> Is this documented as a bug? Am I understanding this correctly?[image:
> Inline image 1]
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131106/5fead1c9/attachment.html>
