[Qgis-user] Configuring the OTB toolbox?
José Pedro Santos
zpsantos1 at hotmail.com
Thu Nov 7 01:33:00 PST 2013
Hi Johanna,
If you are using the version 2.0 you just need to put the path for the OTB files in the configuration menu. In my case, I'm using Linux version (Ubuntu 12.04), put this paths in the configuration menu:
OTB applications folder: /usr/lib/otb
OTB command line tools folder: /usr/lib
Best Regards,
José Santos
> Date: Thu, 7 Nov 2013 08:15:53 +0200
> From: werner.macho at gmail.com
> To: Johanna.Botman at griffith.nsw.gov.au
> CC: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Configuring the OTB toolbox?
> Hi!
> Just to be sure .. first of all you have to have the orfeo toolbox installed
> (http://orfeo-toolbox.org/otb/)
> Then within
> Processing -> Options and configuration -> Providers -> Orfeo Toolbox
> You can set the OTB applications folder and the OTB command line tools folder
> Hope this will help
> regards
> Werner
> On Thu, Nov 7, 2013 at 5:04 AM, <Johanna.Botman at griffith.nsw.gov.au> wrote:
> > I get the following message when I try to run some of the algorithms under
> > the Processing tab.
> > "OTB folder is not configured. Please configure it before running OTB
> > algorithms."
> > Can someone point me in the direction to solve this? I can see that there
> > is no program path if I go into the config settings, but I am not sure what
> > I need to put in there.
> > I have looked under Program Files | Dufour | to see if I can locate the
> > OTB toolbox, but to no avail.
> > _______________
> > Johanna Botman
> > GIS / Assets Officer
> > Griffith City Council
> > Ph: 02 6962 8168
> > Please consider the environment before printing this email notice.
> > This e-mail, together with any attachments, is for the exclusive and
> > confidential use of the addressee(s. Confidentiality is not waived if
> > you are not the intended recipient. Any other distribution, use of,
> > or reproduction without prior written consent is strictly prohibited.
> > Views expressed in this e-mail are those of the individual, except
> > where specifically stated otherwise. If this e-mail has been sent to
> > you in error, please delete the e-mail completely and immediately from
> > your system. Although reasonable precautions are taken, Griffith City
> > Council does not warrant or guarantee this message to be free of errors,
> > interference,viruses or similar malicious code and does not accept
> > liability for any consequences to the recipient opening or using this
> > email or attachments.
> > This email was scanned and cleared by NetIQ MailMarshal and Norman AV
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/62ebd632/attachment.html>
