[Qgis-user] Configuring the OTB toolbox?
Filipe Dias
filipesdias at gmail.com
Thu Nov 7 01:39:38 PST 2013
Isn't OTB available via osge4w?
On Thu, Nov 7, 2013 at 9:33 AM, José Pedro Santos <zpsantos1 at hotmail.com>wrote:
> Hi Johanna,
> If you are using the version 2.0 you just need to put the path for the OTB
> files in the configuration menu. In my case, I'm using Linux version
> (Ubuntu 12.04), put this paths in the configuration menu:
> OTB applications folder: /usr/lib/otb
> OTB command line tools folder: /usr/lib
> Best Regards,
> José Santos
> > Date: Thu, 7 Nov 2013 08:15:53 +0200
> > From: werner.macho at gmail.com
> > To: Johanna.Botman at griffith.nsw.gov.au
> > CC: qgis-user at lists.osgeo.org
> > Subject: Re: [Qgis-user] Configuring the OTB toolbox?
> > Hi!
> > Just to be sure .. first of all you have to have the orfeo toolbox
> installed
> > (http://orfeo-toolbox.org/otb/)
> > Then within
> > Processing -> Options and configuration -> Providers -> Orfeo Toolbox
> > You can set the OTB applications folder and the OTB command line tools
> folder
> > Hope this will help
> > regards
> > Werner
> > On Thu, Nov 7, 2013 at 5:04 AM, <Johanna.Botman at griffith.nsw.gov.au>
> wrote:
> > > I get the following message when I try to run some of the algorithms
> under
> > > the Processing tab.
> > > "OTB folder is not configured. Please configure it before running OTB
> > > algorithms."
> > > Can someone point me in the direction to solve this? I can see that
> there
> > > is no program path if I go into the config settings, but I am not sure
> what
> > > I need to put in there.
> > > I have looked under Program Files | Dufour | to see if I can locate the
> > > OTB toolbox, but to no avail.
> > > _______________
> > > Johanna Botman
> > > GIS / Assets Officer
> > > Griffith City Council
> > > Ph: 02 6962 8168
> > > Please consider the environment before printing this email notice.
> > > This e-mail, together with any attachments, is for the exclusive and
> > > confidential use of the addressee(s. Confidentiality is not waived if
> > > you are not the intended recipient. Any other distribution, use of,
> > > or reproduction without prior written consent is strictly prohibited.
> > > Views expressed in this e-mail are those of the individual, except
> > > where specifically stated otherwise. If this e-mail has been sent to
> > > you in error, please delete the e-mail completely and immediately from
> > > your system. Although reasonable precautions are taken, Griffith City
> > > Council does not warrant or guarantee this message to be free of
> errors,
> > > interference,viruses or similar malicious code and does not accept
> > > liability for any consequences to the recipient opening or using this
> > > email or attachments.
> > > This email was scanned and cleared by NetIQ MailMarshal and Norman AV
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/0e403cfd/attachment.html>
