[Qgis-user] Processing plugin upgrade problem
    Julian Bogdani
    jbogdani at gmail.com
    Thu Nov  7 02:16:23 PST 2013
Hello all,
I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on MacOS X 10.9 (Mavericks)
trying to upgrade Processing plugin, to get advantage of this fix: Bug #8877: Kriging from SAGA (Processing) fails to run I get the following error.
Any hint? Thank you
Couldn't load plugin 'processing' from ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/jbogdani/.qgis2/python', '/Users/jbogdani/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 182, in loadPlugin
    __import__(packageName)
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 453, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py", line 29, in
    from processing.tools.general import *
  File "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py", line 29, in
    from processing.core.Processing import Processing
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py", line 35, in
    from processing.gui.AlgorithmExecutor import AlgorithmExecutor
ImportError: No module named AlgorithmExecutor
Python version:
2.7.5 (default, Aug 25 2013, 00:04:04)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
QGIS version:
2.0.1-Dufour Dufour, f738351
Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/jbogdani/.qgis2/python', '/Users/jbogdani/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
Julian Bogdani
http://bradypus.net
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/38e17552/attachment.html>
