[Qgis-user] Processing plugin upgrade problem
Werner Macho werner.macho at gmail.com
Thu Nov 7 02:18:59 PST 2013
Hi!
I had the same error .. It is nothing serious .. it tells you more or
less that the upgrade was successful .. (because it does not find old
files)
just close and reopen QGIS and everything will be fine ..
regards
Werner
On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com> wrote:
> Hello all,
> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on MacOS X
> 10.9 (Mavericks)
> trying to upgrade Processing plugin, to get advantage of this fix: Bug
> #8877: Kriging from SAGA (Processing) fails to run I get the following
> error.
> Any hint? Thank you
> Couldn't load plugin 'processing' from
> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> '/Users/jbogdani/.qgis2/python', '/Users/jbogdani/.qgis2/python/plugins',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
> '/Library/Python/2.7/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> '/Library/Python/2.7/site-packages',
> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
> Traceback (most recent call last):
>   File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> line 182, in loadPlugin
>     __import__(packageName)
>   File
> line 453, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py", line
> 29, in
>     from processing.tools.general import *
>   File
>   File "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
> line 29, in
>     from processing.core.Processing import Processing
>   File
>   File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
> line 35, in
>     from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>   File
> ImportError: No module named AlgorithmExecutor
> Python version:
> 2.7.5 (default, Aug 25 2013, 00:04:04)
> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
> QGIS version:
> 2.0.1-Dufour Dufour, f738351
> Python path:
> Julian Bogdani
> http://bradypus.net
> Qgis-user mailing list
