[Qgis-user] Processing plugin upgrade problem
G. Allegri
giohappy at gmail.com
Thu Nov 7 02:23:21 PST 2013
I've noticed that it happens with Windows standalone installer too but not
with OSGeo4W.
giovanni
2013/11/7 Werner Macho <werner.macho at gmail.com>
> Hi!
> I had the same error .. It is nothing serious .. it tells you more or
> less that the upgrade was successful .. (because it does not find old
> files)
> just close and reopen QGIS and everything will be fine ..
> regards
> Werner
> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
> wrote:
> > Hello all,
> > I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
> MacOS X
> > 10.9 (Mavericks)
> > trying to upgrade Processing plugin, to get advantage of this fix: Bug
> > #8877: Kriging from SAGA (Processing) fails to run I get the following
> > error.
> > Any hint? Thank you
> > Couldn't load plugin 'processing' from
> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> > '/Users/jbogdani/.qgis2/python', '/Users/jbogdani/.qgis2/python/plugins',
> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> > '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
> > '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
> > '/Library/Python/2.7/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> > '/Library/Python/2.7/site-packages',
> > '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
> > Traceback (most recent call last):
> > File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> > line 182, in loadPlugin
> > __import__(packageName)
> > File
> > line 453, in _import
> > mod = _builtin_import(name, globals, locals, fromlist, level)
> > File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
> line
> > 29, in
> > from processing.tools.general import *
> > File
> > File
> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
> > line 29, in
> > from processing.core.Processing import Processing
> > File
> > File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
> > line 35, in
> > from processing.gui.AlgorithmExecutor import AlgorithmExecutor
> > File
> > ImportError: No module named AlgorithmExecutor
> > Python version:
> > 2.7.5 (default, Aug 25 2013, 00:04:04)
> > [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
> > QGIS version:
> > 2.0.1-Dufour Dufour, f738351
> > Python path:
> > Julian Bogdani
> > http://bradypus.net
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Giovanni Allegri
http://about.me/giovanniallegri
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/dcfef7a6/attachment.html>
