[Qgis-user] Processing plugin upgrade problem
Julian Bogdani
jbogdani at gmail.com
Thu Nov 7 02:34:15 PST 2013
Trying to run any SAGA algorithm I get this message now:
Missing dependency.This algorithm cannot be run :-(
This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is not installed in your system, or it is not correctly configured to be used from QGIS
Click here to know more about how to install and configure SAGA to be used with QGIS
I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA was activated (Processing > Options and Configurations > Providers > SAGA)
Julian Bogdani
http://bradypus.net
On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
> I've noticed that it happens with Windows standalone installer too but not with OSGeo4W.
> giovanni
> 2013/11/7 Werner Macho <werner.macho at gmail.com>
> Hi!
> I had the same error .. It is nothing serious .. it tells you more or
> less that the upgrade was successful .. (because it does not find old
> files)
> just close and reopen QGIS and everything will be fine ..
> regards
> Werner
> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com> wrote:
> > Hello all,
> > I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on MacOS X
> > 10.9 (Mavericks)
> > trying to upgrade Processing plugin, to get advantage of this fix: Bug
> > #8877: Kriging from SAGA (Processing) fails to run I get the following
> > error.
> > Any hint? Thank you
> > Couldn't load plugin 'processing' from
> > ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> > '/Users/jbogdani/.qgis2/python', '/Users/jbogdani/.qgis2/python/plugins',
> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> > '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
> > '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
> > '/Library/Python/2.7/site-packages/numpy-override',
> > '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> > '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> > '/Library/Python/2.7/site-packages',
> > '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
> > Traceback (most recent call last):
> > File
> > "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> > line 182, in loadPlugin
> > __import__(packageName)
> > File
> > line 453, in _import
> > mod = _builtin_import(name, globals, locals, fromlist, level)
> > File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py", line
> > 29, in
> > from processing.tools.general import *
> > File
> > File "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
> > line 29, in
> > from processing.core.Processing import Processing
> > File
> > File
> > "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
> > line 35, in
> > from processing.gui.AlgorithmExecutor import AlgorithmExecutor
> > File
> > ImportError: No module named AlgorithmExecutor
> > Python version:
> > 2.7.5 (default, Aug 25 2013, 00:04:04)
> > [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
> > QGIS version:
> > 2.0.1-Dufour Dufour, f738351
> > Python path:
> > Julian Bogdani
> > http://bradypus.net
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giovanni Allegri
> http://about.me/giovanniallegri
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/ac22da5d/attachment.html>
