[Qgis-user] Processing plugin upgrade problem
Victor Olaya
volayaf at gmail.com
Thu Nov 7 02:37:09 PST 2013
Is SAGA installed and in PATH? can you open a console and run
saga_cmd? what do you get?
Notice that SAGA 2.1.0 is needed in mac, but the default Processing
configuration is to have 2.0.8 compatibility enabled...
2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
> Trying to run any SAGA algorithm I get this message now:
> Missing dependency.This algorithm cannot be run :-(
> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
> not installed in your system, or it is not correctly configured to be used
> from QGIS
> Click here to know more about how to install and configure SAGA to be used
> with QGIS
> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
> was activated (Processing > Options and Configurations > Providers > SAGA)
> Julian Bogdani
> http://bradypus.net
> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
> I've noticed that it happens with Windows standalone installer too but not
> with OSGeo4W.
> giovanni
> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>> Hi!
>> I had the same error .. It is nothing serious .. it tells you more or
>> less that the upgrade was successful .. (because it does not find old
>> files)
>> just close and reopen QGIS and everything will be fine ..
>> regards
>> Werner
>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>> wrote:
>> > Hello all,
>> > I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>> > MacOS X
>> > 10.9 (Mavericks)
>> > trying to upgrade Processing plugin, to get advantage of this fix: Bug
>> > #8877: Kriging from SAGA (Processing) fails to run I get the following
>> > error.
>> > Any hint? Thank you
>> > Couldn't load plugin 'processing' from
>> > ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>> > '/Users/jbogdani/.qgis2/python',
>> > '/Users/jbogdani/.qgis2/python/plugins',
>> > '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>> > '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>> > '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>> > '/Library/Python/2.7/site-packages/numpy-override',
>> > '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>> > '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>> > '/Library/Python/2.7/site-packages',
>> > '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>> > Traceback (most recent call last):
>> > File
>> > "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>> > line 182, in loadPlugin
>> > __import__(packageName)
>> > File
>> > line 453, in _import
>> > mod = _builtin_import(name, globals, locals, fromlist, level)
>> > File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>> > line
>> > 29, in
>> > from processing.tools.general import *
>> > File
>> > File
>> > "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>> > line 29, in
>> > from processing.core.Processing import Processing
>> > File
>> > File
>> > "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>> > line 35, in
>> > from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>> > File
>> > ImportError: No module named AlgorithmExecutor
>> > Python version:
>> > 2.7.5 (default, Aug 25 2013, 00:04:04)
>> > [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>> > QGIS version:
>> > 2.0.1-Dufour Dufour, f738351
>> > Python path:
>> > Julian Bogdani
>> > http://bradypus.net
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giovanni Allegri
> http://about.me/giovanniallegri
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
