[Qgis-user] Processing plugin upgrade problem
    Julian Bogdani
    jbogdani at gmail.com
    Thu Nov  7 02:51:52 PST 2013
Hi Victor,
SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my .bash_profile file
Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
Closing QGIS and restarting, I found no changes, still the same error when I try to run any SAGA algorithm: Missing dependency
Should I install Saga separately?
On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
> Is SAGA installed and in PATH? can you open a console and run
> saga_cmd? what do you get?
> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
> configuration is to have 2.0.8 compatibility enabled...
> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>> Trying to run any SAGA algorithm I get this message now:
>> Missing dependency.This algorithm cannot be run :-(
>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>> not installed in your system, or it is not correctly configured to be used
>> from QGIS
>> Click here to know more about how to install and configure SAGA to be used
>> with QGIS
>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>> was activated (Processing > Options and Configurations > Providers > SAGA)
>> Julian Bogdani
>> http://bradypus.net
>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>> I've noticed that it happens with Windows standalone installer too but not
>> with OSGeo4W.
>> giovanni
>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>>> Hi!
>>> I had the same error .. It is nothing serious .. it tells you more or
>>> less that the upgrade was successful .. (because it does not find old
>>> files)
>>> just close and reopen QGIS and everything will be fine ..
>>> regards
>>> Werner
>>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>>> wrote:
>>>> Hello all,
>>>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>>>> MacOS X
>>>> 10.9 (Mavericks)
>>>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>>>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>>>> error.
>>>> Any hint? Thank you
>>>> Couldn't load plugin 'processing' from
>>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>>> '/Users/jbogdani/.qgis2/python',
>>>> '/Users/jbogdani/.qgis2/python/plugins',
>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>>>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>>>> '/Library/Python/2.7/site-packages/numpy-override',
>>>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>>> '/Library/Python/2.7/site-packages',
>>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>>>> Traceback (most recent call last):
>>>>  File
>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>>> line 182, in loadPlugin
>>>>    __import__(packageName)
>>>>  File
>>>> line 453, in _import
>>>>    mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>  File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>>>> line
>>>> 29, in
>>>>    from processing.tools.general import *
>>>>  File
>>>>  File
>>>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>>>> line 29, in
>>>>    from processing.core.Processing import Processing
>>>>  File
>>>>  File
>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>>>> line 35, in
>>>>    from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>>>>  File
>>>> ImportError: No module named AlgorithmExecutor
>>>> Python version:
>>>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>>>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>>>> QGIS version:
>>>> 2.0.1-Dufour Dufour, f738351
>>>> Python path:
>>>> Julian Bogdani
>>>> http://bradypus.net
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/42656671/attachment.html>
