[Qgis-user] Processing plugin upgrade problem
Victor Olaya
volayaf at gmail.com
Thu Nov 7 02:31:48 PST 2013
The plugin manager is trying to load a module that is not anymore in
processing. It should be fine if you just close it, and the plugin
should be updated. In case you have problems, just first uninstall the
older version (also with the plugin manager) and then reinstall the
newer version
Hope this helps
2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
> Hello all,
> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on MacOS X
> 10.9 (Mavericks)
> trying to upgrade Processing plugin, to get advantage of this fix: Bug
> #8877: Kriging from SAGA (Processing) fails to run I get the following
> error.
> Any hint? Thank you
> Couldn't load plugin 'processing' from
> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
> '/Users/jbogdani/.qgis2/python', '/Users/jbogdani/.qgis2/python/plugins',
> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
> '/Library/Python/2.7/site-packages/numpy-override',
> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
> '/Library/Python/2.7/site-packages',
> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
> Traceback (most recent call last):
> File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
> line 182, in loadPlugin
> __import__(packageName)
> File
> line 453, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py", line
> 29, in
> from processing.tools.general import *
> File
> File "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
> line 29, in
> from processing.core.Processing import Processing
> File
> File
> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
> line 35, in
> from processing.gui.AlgorithmExecutor import AlgorithmExecutor
> File
> ImportError: No module named AlgorithmExecutor
> Python version:
> 2.7.5 (default, Aug 25 2013, 00:04:04)
> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
> QGIS version:
> 2.0.1-Dufour Dufour, f738351
> Python path:
> Julian Bogdani
> http://bradypus.net
> Qgis-user mailing list
