[Qgis-user] Processing plugin upgrade problem
Jesus Munoz Serrano
jesusmunozserrano at gmail.com
Thu Nov 7 03:10:44 PST 2013
Hi Julian,
I had the same warning when I upgraded the processing plugin (I am using mac OS X 10.8 and QGIS 2.0.1). I exit QGIS and open it again and the processing plugin was there. Then I used kernel density estimation algorithm inside the SAGA group and it worked fine. What algorithm have you try? Can I check anything in my computer to help you?
On Nov 7, 2013, at 11:54 AM, Victor Olaya <volayaf at gmail.com> wrote:
> No, that should be enough, but unfortunately my knowledge of Mac OSX
> is zero, so i am afraid I cannot help you. Let's see if other mac
> users can help you... :-(
> Cheers
> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>> Hi Victor,
>> SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in
>> /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my
>> .bash_profile file
>> Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
>> Closing QGIS and restarting, I found no changes, still the same error when I
>> try to run any SAGA algorithm: Missing dependency
>> Should I install Saga separately?
>> On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
>> Is SAGA installed and in PATH? can you open a console and run
>> saga_cmd? what do you get?
>> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
>> configuration is to have 2.0.8 compatibility enabled...
>> Trying to run any SAGA algorithm I get this message now:
>> Missing dependency.This algorithm cannot be run :-(
>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>> not installed in your system, or it is not correctly configured to be used
>> from QGIS
>> Click here to know more about how to install and configure SAGA to be used
>> with QGIS
>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>> was activated (Processing > Options and Configurations > Providers > SAGA)
>> Julian Bogdani
>> http://bradypus.net
>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>> I've noticed that it happens with Windows standalone installer too but not
>> with OSGeo4W.
>> giovanni
>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>> Hi!
>> I had the same error .. It is nothing serious .. it tells you more or
>> less that the upgrade was successful .. (because it does not find old
>> files)
>> just close and reopen QGIS and everything will be fine ..
>> regards
>> Werner
>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>> wrote:
>> Hello all,
>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>> MacOS X
>> 10.9 (Mavericks)
>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>> error.
>> Any hint? Thank you
>> Couldn't load plugin 'processing' from
>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>> '/Users/jbogdani/.qgis2/python',
>> '/Users/jbogdani/.qgis2/python/plugins',
>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>> '/Library/Python/2.7/site-packages/numpy-override',
>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>> '/Library/Python/2.7/site-packages',
>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>> Traceback (most recent call last):
>> File
>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>> line 182, in loadPlugin
>> __import__(packageName)
>> File
>> line 453, in _import
>> mod = _builtin_import(name, globals, locals, fromlist, level)
>> File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>> line
>> 29, in
>> from processing.tools.general import *
>> File
>> File
>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>> line 29, in
>> from processing.core.Processing import Processing
>> File
>> File
>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>> line 35, in
>> from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>> File
>> ImportError: No module named AlgorithmExecutor
>> Python version:
>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>> QGIS version:
>> 2.0.1-Dufour Dufour, f738351
>> Python path:
>> Julian Bogdani
>> http://bradypus.net
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> Giovanni Allegri
>> http://about.me/giovanniallegri
>> blog: http://blog.spaziogis.it
>> GEO+ geomatica in Italia http://bit.ly/GEOplus
