[Qgis-user] Processing plugin upgrade problem
Julian Bogdani
jbogdani at gmail.com
Thu Nov 7 03:27:27 PST 2013
Hello,
Could you please copy&paste the value of the PATH variable in Settings > Options > System > Current environment variables
I do not have the /Applications/QGIS.app/Contents/MacOS/bin in this list and I’m not able to add it manually (this is a read only list)
Actually this is the value of my PATH variable: /Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
Julian Bogdani
http://bradypus.net
On 7 Nov 2013, at 12:10 , Jesus Munoz Serrano <jesusmunozserrano at gmail.com> wrote:
> Hi Julian,
> I had the same warning when I upgraded the processing plugin (I am using mac OS X 10.8 and QGIS 2.0.1). I exit QGIS and open it again and the processing plugin was there. Then I used kernel density estimation algorithm inside the SAGA group and it worked fine. What algorithm have you try? Can I check anything in my computer to help you?
> On Nov 7, 2013, at 11:54 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> No, that should be enough, but unfortunately my knowledge of Mac OSX
>> is zero, so i am afraid I cannot help you. Let's see if other mac
>> users can help you... :-(
>> Cheers
>> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>>> Hi Victor,
>>> SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in
>>> /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my
>>> .bash_profile file
>>> Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
>>> Closing QGIS and restarting, I found no changes, still the same error when I
>>> try to run any SAGA algorithm: Missing dependency
>>> Should I install Saga separately?
>>> On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
>>> Is SAGA installed and in PATH? can you open a console and run
>>> saga_cmd? what do you get?
>>> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
>>> configuration is to have 2.0.8 compatibility enabled...
>>> Trying to run any SAGA algorithm I get this message now:
>>> Missing dependency.This algorithm cannot be run :-(
>>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>>> not installed in your system, or it is not correctly configured to be used
>>> from QGIS
>>> Click here to know more about how to install and configure SAGA to be used
>>> with QGIS
>>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>>> was activated (Processing > Options and Configurations > Providers > SAGA)
>>> Julian Bogdani
>>> http://bradypus.net
>>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>>> I've noticed that it happens with Windows standalone installer too but not
>>> with OSGeo4W.
>>> giovanni
>>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>>> Hi!
>>> I had the same error .. It is nothing serious .. it tells you more or
>>> less that the upgrade was successful .. (because it does not find old
>>> files)
>>> just close and reopen QGIS and everything will be fine ..
>>> regards
>>> Werner
>>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>>> wrote:
>>> Hello all,
>>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>>> MacOS X
>>> 10.9 (Mavericks)
>>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>>> error.
>>> Any hint? Thank you
>>> Couldn't load plugin 'processing' from
>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>> '/Users/jbogdani/.qgis2/python',
>>> '/Users/jbogdani/.qgis2/python/plugins',
>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>>> '/Library/Python/2.7/site-packages/numpy-override',
>>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>> '/Library/Python/2.7/site-packages',
>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>>> Traceback (most recent call last):
>>> File
>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>> line 182, in loadPlugin
>>> __import__(packageName)
>>> File
>>> line 453, in _import
>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>> File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>>> line
>>> 29, in
>>> from processing.tools.general import *
>>> File
>>> File
>>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>>> line 29, in
>>> from processing.core.Processing import Processing
>>> File
>>> File
>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>>> line 35, in
>>> from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>>> File
>>> ImportError: No module named AlgorithmExecutor
>>> Python version:
>>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>>> QGIS version:
>>> 2.0.1-Dufour Dufour, f738351
>>> Python path:
>>> Julian Bogdani
>>> http://bradypus.net
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131107/d11e80e5/attachment.html>
