[Qgis-user] Processing plugin upgrade problem
Julian Bogdani
jbogdani at gmail.com
Thu Nov 7 03:50:15 PST 2013
Thanks,
If I downgrade the Processing Plugin (from v2.0-20131029 to v1.1), it does not complain for the missing installation, but Kriging does not work.
PS I’m getting the same error (Missing dependency.This algorithm cannot be run :-( ) on several Grass algorithms as well. These functions worked fine before the upgrade.
Julian Bogdani
http://bradypus.net
On 7 Nov 2013, at 12:33 , Jesus Munoz Serrano <jesusmunozserrano at gmail.com> wrote:
> It looks exactly the same:
> /Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
> On Nov 7, 2013, at 12:27 PM, Julian Bogdani <jbogdani at gmail.com> wrote:
>> Hello,
>> Could you please copy&paste the value of the PATH variable in Settings > Options > System > Current environment variables
>> I do not have the /Applications/QGIS.app/Contents/MacOS/bin in this list and I’m not able to add it manually (this is a read only list)
>> Actually this is the value of my PATH variable: /Applications/QGIS.app/Contents/MacOS/grass/bin:/Applications/QGIS.app/Contents/MacOS/grass/scripts:/Applications/QGIS.app/Contents/MacOS/../Resources/grass/scripts/:/usr/bin:/bin:/usr/sbin:/sbin
>> Julian Bogdani
>> http://bradypus.net
>> On 7 Nov 2013, at 12:10 , Jesus Munoz Serrano <jesusmunozserrano at gmail.com> wrote:
>>> Hi Julian,
>>> I had the same warning when I upgraded the processing plugin (I am using mac OS X 10.8 and QGIS 2.0.1). I exit QGIS and open it again and the processing plugin was there. Then I used kernel density estimation algorithm inside the SAGA group and it worked fine. What algorithm have you try? Can I check anything in my computer to help you?
>>> On Nov 7, 2013, at 11:54 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>>> No, that should be enough, but unfortunately my knowledge of Mac OSX
>>>> is zero, so i am afraid I cannot help you. Let's see if other mac
>>>> users can help you... :-(
>>>> Cheers
>>>> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>>>>> Hi Victor,
>>>>> SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in
>>>>> /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my
>>>>> .bash_profile file
>>>>> Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
>>>>> Closing QGIS and restarting, I found no changes, still the same error when I
>>>>> try to run any SAGA algorithm: Missing dependency
>>>>> Should I install Saga separately?
>>>>> On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
>>>>> Is SAGA installed and in PATH? can you open a console and run
>>>>> saga_cmd? what do you get?
>>>>> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
>>>>> configuration is to have 2.0.8 compatibility enabled...
>>>>> Trying to run any SAGA algorithm I get this message now:
>>>>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>>>>> not installed in your system, or it is not correctly configured to be used
>>>>> from QGIS
>>>>> Click here to know more about how to install and configure SAGA to be used
>>>>> with QGIS
>>>>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>>>>> was activated (Processing > Options and Configurations > Providers > SAGA)
>>>>> Julian Bogdani
>>>>> http://bradypus.net
>>>>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>>>>> I've noticed that it happens with Windows standalone installer too but not
>>>>> with OSGeo4W.
>>>>> giovanni
>>>>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>>>>> Hi!
>>>>> I had the same error .. It is nothing serious .. it tells you more or
>>>>> less that the upgrade was successful .. (because it does not find old
>>>>> files)
>>>>> just close and reopen QGIS and everything will be fine ..
>>>>> regards
>>>>> Werner
>>>>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>>>>> wrote:
>>>>> Hello all,
>>>>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>>>>> MacOS X
>>>>> 10.9 (Mavericks)
>>>>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>>>>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>>>>> error.
>>>>> Any hint? Thank you
>>>>> Couldn't load plugin 'processing' from
>>>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>>>> '/Users/jbogdani/.qgis2/python',
>>>>> '/Users/jbogdani/.qgis2/python/plugins',
>>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>>>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>>>>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>>>>> '/Library/Python/2.7/site-packages/numpy-override',
>>>>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>>>> '/Library/Python/2.7/site-packages',
>>>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>>>>> Traceback (most recent call last):
>>>>> File
>>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>>>> line 182, in loadPlugin
>>>>> __import__(packageName)
>>>>> File
>>>>> line 453, in _import
>>>>> mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>> File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>>>>> line
>>>>> 29, in
>>>>> from processing.tools.general import *
>>>>> File
>>>>> File
>>>>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>>>>> line 29, in
>>>>> from processing.core.Processing import Processing
>>>>> File
>>>>> File
>>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>>>>> line 35, in
>>>>> from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>>>>> File
>>>>> ImportError: No module named AlgorithmExecutor
>>>>> Python version:
>>>>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>>>>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>>>>> QGIS version:
>>>>> 2.0.1-Dufour Dufour, f738351
>>>>> Python path:
>>>>> Julian Bogdani
>>>>> http://bradypus.net
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Giovanni Allegri
>>>>> http://about.me/giovanniallegri
>>>>> blog: http://blog.spaziogis.it
>>>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
