[Qgis-user] Processing plugin upgrade problem
    William Kyngesburye
    woklist at kyngchaos.com
    Thu Nov  7 07:15:36 PST 2013
I updated Processing, no missing dependency errors after restarting QGIS.
A couple things to check: turn on the "Keep dialog open after running algorithm" general option, you can then see more details of the problem in the log window after closing the error dialog.  The missing dependency error may be misleading.
Also make sure to uncheck the SAGA 2.0.8 compatibility option (providers/SAGA).  Victor: maybe the default should detect the system and uncheck it automatically for OS X?
So, I don't get missing dependency error, I do get this for kriging in the log:
 Unknown option 'USER_FIT'
On Nov 7, 2013, at 4:51 AM, Julian Bogdani wrote:
> Hi Victor,
> SAGA should be installed with QGIS, isn’t it? I can see the saga_cmd in /Applications/QGIS.app/Contents/MacOS/bin and I added this path to my .bash_profile file
> Running saga_cmd -v on my terminal I have: SAGA Version: 2.1.0
> Closing QGIS and restarting, I found no changes, still the same error when I try to run any SAGA algorithm: Missing dependency
> Should I install Saga separately?
> On 7 Nov 2013, at 11:37 , Victor Olaya <volayaf at gmail.com> wrote:
>> Is SAGA installed and in PATH? can you open a console and run
>> saga_cmd? what do you get?
>> Notice that SAGA 2.1.0 is needed in mac, but the default Processing
>> configuration is to have 2.0.8 compatibility enabled...
>> 2013/11/7 Julian Bogdani <jbogdani at gmail.com>:
>>> Trying to run any SAGA algorithm I get this message now:
>>> Missing dependency.This algorithm cannot be run :-(
>>> This algorithm requires SAGA to be run.Unfortunately, it seems that SAGA is
>>> not installed in your system, or it is not correctly configured to be used
>>> from QGIS
>>> Click here to know more about how to install and configure SAGA to be used
>>> with QGIS
>>> I just reinstalled GDAL and QGIS, upgraded Processing, and checked that SAGA
>>> was activated (Processing > Options and Configurations > Providers > SAGA)
>>> Julian Bogdani
>>> http://bradypus.net
>>> On 7 Nov 2013, at 11:23 , G. Allegri <giohappy at gmail.com> wrote:
>>> I've noticed that it happens with Windows standalone installer too but not
>>> with OSGeo4W.
>>> giovanni
>>> 2013/11/7 Werner Macho <werner.macho at gmail.com>
>>>> Hi!
>>>> I had the same error .. It is nothing serious .. it tells you more or
>>>> less that the upgrade was successful .. (because it does not find old
>>>> files)
>>>> just close and reopen QGIS and everything will be fine ..
>>>> regards
>>>> Werner
>>>> On Thu, Nov 7, 2013 at 12:16 PM, Julian Bogdani <jbogdani at gmail.com>
>>>> wrote:
>>>>> Hello all,
>>>>> I’m running latest QGIS (2.0.1-3) installed from Kyngchaos repo, on
>>>>> MacOS X
>>>>> 10.9 (Mavericks)
>>>>> trying to upgrade Processing plugin, to get advantage of this fix: Bug
>>>>> #8877: Kriging from SAGA (Processing) fails to run I get the following
>>>>> error.
>>>>> Any hint? Thank you
>>>>> Couldn't load plugin 'processing' from
>>>>> ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing',
>>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python',
>>>>> '/Users/jbogdani/.qgis2/python',
>>>>> '/Users/jbogdani/.qgis2/python/plugins',
>>>>> '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins',
>>>>> '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
>>>>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7',
>>>>> '/Library/Python/2.7/site-packages/numpy-override',
>>>>> '/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
>>>>> '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
>>>>> '/Library/Python/2.7/site-packages',
>>>>> '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools']
>>>>> Traceback (most recent call last):
>>>>>  File
>>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py",
>>>>> line 182, in loadPlugin
>>>>>    __import__(packageName)
>>>>>  File
>>>>> line 453, in _import
>>>>>    mod = _builtin_import(name, globals, locals, fromlist, level)
>>>>>  File "/Users/jbogdani/.qgis2/python/plugins/processing/__init__.py",
>>>>> line
>>>>> 29, in
>>>>>    from processing.tools.general import *
>>>>>  File
>>>>>  File
>>>>> "/Users/jbogdani/.qgis2/python/plugins/processing/tools/general.py",
>>>>> line 29, in
>>>>>    from processing.core.Processing import Processing
>>>>>  File
>>>>>  File
>>>>> "/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing/core/Processing.py",
>>>>> line 35, in
>>>>>    from processing.gui.AlgorithmExecutor import AlgorithmExecutor
>>>>>  File
>>>>> ImportError: No module named AlgorithmExecutor
>>>>> Python version:
>>>>> 2.7.5 (default, Aug 25 2013, 00:04:04)
>>>>> [GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
>>>>> QGIS version:
>>>>> 2.0.1-Dufour Dufour, f738351
>>>>> Python path:
>>>>> Julian Bogdani
>>>>> http://bradypus.net
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
