[Qgis-user] Configuring the OTB toolbox?
Johanna.Botman at griffith.nsw.gov.au
Thu Nov 7 13:34:03 PST 2013
Thank you for your answers.
Werner, I was aware of that setting. What I find there is that there is an
'x' in the Activate box, but no file path. So I looked for the file path by
using Windows Explorer and couldn't find it.
Jose, I am using Windows 7 and QGIS version 2. I looked for your suggested
file path, but again, no luck.
Perhaps I have made the mistake of assuming that if I can see the entries
for Orfeo Toolbox in the Processing Toolbox then it is installed.
My installation of QGIS was done via the Windows installer, not through
Osgeo. Would I be right, now, to say that I need it as a separate
installation?
_______________
Johanna Botman
GIS / Assets Officer
Griffith City Council
Ph: 02 6962 8168
To: "Johanna.Botman at griffith.nsw.gov.au"
<johanna.botman at griffith.nsw.gov.au>,
Cc: QGIS Mailing List <qgis-user at lists.osgeo.org>
Date: 07/11/2013 08:33 PM
Subject: RE: [Qgis-user] Configuring the OTB toolbox?
Hi Johanna,
If you are using the version 2.0 you just need to put the path for the OTB
files in the configuration menu. In my case, I'm using Linux version
(Ubuntu 12.04), put this paths in the configuration menu:
OTB applications folder: /usr/lib/otb
OTB command line tools folder: /usr/lib
Best Regards,
José Santos
> Date: Thu, 7 Nov 2013 08:15:53 +0200
> From: werner.macho at gmail.com
> To: Johanna.Botman at griffith.nsw.gov.au
> CC: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Configuring the OTB toolbox?
> Hi!
> Just to be sure .. first of all you have to have the orfeo toolbox
installed
> (http://orfeo-toolbox.org/otb/)
> Then within
> Processing -> Options and configuration -> Providers -> Orfeo Toolbox
> You can set the OTB applications folder and the OTB command line tools
folder
> Hope this will help
> regards
> Werner
> On Thu, Nov 7, 2013 at 5:04 AM, <Johanna.Botman at griffith.nsw.gov.au>
wrote:
> > I get the following message when I try to run some of the algorithms
under
> > the Processing tab.
> > "OTB folder is not configured. Please configure it before running OTB
> > algorithms."
> > Can someone point me in the direction to solve this? I can see that
there
> > is no program path if I go into the config settings, but I am not sure
what
> > I need to put in there.
> > I have looked under Program Files | Dufour | to see if I can locate the
> > OTB toolbox, but to no avail.
> > _______________
> > Johanna Botman
> > Ph: 02 6962 8168
Please consider the environment before printing this email notice.
This e-mail, together with any attachments, is for the exclusive and
confidential use of the addressee(s. Confidentiality is not waived if
you are not the intended recipient. Any other distribution, use of,
or reproduction without prior written consent is strictly prohibited.
Views expressed in this e-mail are those of the individual, except
where specifically stated otherwise. If this e-mail has been sent to
you in error, please delete the e-mail completely and immediately from
your system. Although reasonable precautions are taken, Griffith City
Council does not warrant or guarantee this message to be free of errors,
interference,viruses or similar malicious code and does not accept
liability for any consequences to the recipient opening or using this
email or attachments.
This email was scanned and cleared by NetIQ MailMarshal and Norman AV
