[Qgis-user] Configuring the OTB toolbox?
Saulteau Don
sault.don at gmail.com
Thu Nov 7 14:19:34 PST 2013
Hey Johanna, I just got OTB working today.
Here's what I did, because I did notice that it isn't installed
through the Stand Alone QGIS installer or the 64bit OSGeo4W packager.
Download both:
(1) otb-bin and (2) otb-python tar.bz2 files from
http://orfeo-toolbox.org/packages/nightly/latest
These are nightly builds, but the only place I've found with current
Windows files needed for processing toolbox. So you can come back and
get them everyday if you like =P
They both contain a tar file after you first extract them.
Extract the contents of those tar files (you should see folders like
apps, bin, etc) to your QGIS directory so they merge with your
existing apps, bin and etc folders.
If you installed with OSGeo4W, you simply drop them into the OSGeo4W
folder, for example.
Now you should be able to simply activate the OTB tools in the
"providers" config window for the processing toolbox without having to
specify a path to the OTB libs and such. They should be found
automatically.
Donovan
On Thu, Nov 7, 2013 at 2:34 PM, <Johanna.Botman at griffith.nsw.gov.au> wrote:
> Thank you for your answers.
> Werner, I was aware of that setting. What I find there is that there is an
> 'x' in the Activate box, but no file path. So I looked for the file path by
> using Windows Explorer and couldn't find it.
> Jose, I am using Windows 7 and QGIS version 2. I looked for your suggested
> file path, but again, no luck.
> Perhaps I have made the mistake of assuming that if I can see the entries
> for Orfeo Toolbox in the Processing Toolbox then it is installed.
> My installation of QGIS was done via the Windows installer, not through
> Osgeo. Would I be right, now, to say that I need it as a separate
> installation?
> _______________
> Johanna Botman
> GIS / Assets Officer
> Griffith City Council
> Ph: 02 6962 8168
> From: José Pedro Santos <zpsantos1 at hotmail.com>
> To: "Johanna.Botman at griffith.nsw.gov.au"
> <johanna.botman at griffith.nsw.gov.au>,
> Cc: QGIS Mailing List <qgis-user at lists.osgeo.org>
> Date: 07/11/2013 08:33 PM
> Subject: RE: [Qgis-user] Configuring the OTB toolbox?
> Hi Johanna,
> If you are using the version 2.0 you just need to put the path for the OTB
> files in the configuration menu. In my case, I'm using Linux version
> (Ubuntu 12.04), put this paths in the configuration menu:
> OTB applications folder: /usr/lib/otb
> OTB command line tools folder: /usr/lib
> Best Regards,
> José Santos
>> Date: Thu, 7 Nov 2013 08:15:53 +0200
>> From: werner.macho at gmail.com
>> To: Johanna.Botman at griffith.nsw.gov.au
>> CC: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] Configuring the OTB toolbox?
>> Hi!
>> Just to be sure .. first of all you have to have the orfeo toolbox
> installed
>> (http://orfeo-toolbox.org/otb/)
>> Then within
>> Processing -> Options and configuration -> Providers -> Orfeo Toolbox
>> You can set the OTB applications folder and the OTB command line tools
> folder
>> Hope this will help
>> regards
>> Werner
>> On Thu, Nov 7, 2013 at 5:04 AM, <Johanna.Botman at griffith.nsw.gov.au>
> wrote:
>> > I get the following message when I try to run some of the algorithms
> under
>> > the Processing tab.
>> > "OTB folder is not configured. Please configure it before running OTB
>> > algorithms."
>> > Can someone point me in the direction to solve this? I can see that
> there
>> > is no program path if I go into the config settings, but I am not sure
> what
>> > I need to put in there.
>> > I have looked under Program Files | Dufour | to see if I can locate the
>> > OTB toolbox, but to no avail.
>> > _______________
>> > Johanna Botman
>> > Ph: 02 6962 8168
> Please consider the environment before printing this email notice.
> This e-mail, together with any attachments, is for the exclusive and
> confidential use of the addressee(s. Confidentiality is not waived if
> you are not the intended recipient. Any other distribution, use of,
> or reproduction without prior written consent is strictly prohibited.
> Views expressed in this e-mail are those of the individual, except
> where specifically stated otherwise. If this e-mail has been sent to
> you in error, please delete the e-mail completely and immediately from
> your system. Although reasonable precautions are taken, Griffith City
> Council does not warrant or guarantee this message to be free of errors,
> interference,viruses or similar malicious code and does not accept
> liability for any consequences to the recipient opening or using this
> email or attachments.
> This email was scanned and cleared by NetIQ MailMarshal and Norman AV
> Qgis-user mailing list
