[Qgis-user] How do I configure GPS Plugin on QGIS
    Harish
    harry.om2000 at gmail.com
    Mon Nov 11 02:12:33 PST 2013
I have GARMIN Map78s GPS and not able to work with 'GPS Tools'. I read that
'GPS tools' uses GPSBabel, and Manual of GPSBabel (page 47-48) says for
Map78s and some other models that,
"The following Garmin GPS receivers are supported, but they do not support
Garmin communication
protocol and don't work with the garmin option. To use these receivers,
read or write GPX files from
the mass storage device as mounted on your computer."
Problem may lies here or in our method/steps.
Regards
On Sat, Nov 9, 2013 at 8:12 AM, Michael White <crwban681 at yahoo.co.uk> wrote:
> I've just installed stand alone QGIS OSGeo4W-2.0.1-3-Setup-x86 ~ no
> problems; I'm a first time user. I'm trying to import waypoint data (GPX)
> from a Garmin MapSource78.
> Plugin Manager says the GPS tools plugin is there, the box is checked. Add
> vector layer from GPS in menu can find my GPS (usb) and locate the files on
> that receiver. It imports the GPX file title into layers manager, shows the
> corordinate properties as WGS84, and I click OK. Then it says Plugin not
> configured.
> I've reloaded the repository, but the GPS icons do not appear anywhere on
> toolbars or menus (the manual says they should). How do I configure the
> plugin? Thanks, Michael
> Dr Michael White
> Marine Zoologist
> Tongareva Atoll
> Northern Cook Islands
> Member of IUCN - Species Survival Commission:
> Marine Turtle Specialist Group
> Qgis-user mailing list
Harish Kumar Solanki, Assistant Professor
National Institute of Rural Development (NIRD),
Ministry of Rural Development, Government of India
Jaipur, Rajasthan, India- Pin-302006
Geo_Coordinates (Office): 26.92162 N, 75.78921 E
Email- hksolanki at nird.gov.in, harry.om2000 at gmail.com,
Tele-Fax-0141-2209905, Mo.- 09214446732, 09414291732
Website-  http://www.nird.org.in,
http://watershed.rajasthan.gov.in/<http://www.nird.org.in>
LinkedIn: www.linkedIn.com/in/hksolanki
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131111/59196337/attachment.html>
