[Qgis-user] DB manager don't load postgis tables (not geometric	tables)
    Pietro Rossin
    pierigis at gmail.com
    Tue Nov 12 05:32:47 PST 2013
Hello
As I understood db manager should load alphanumeric tables, right?
In my installation of qgis (2.0.1) it doesn't..
When I try to drag and drop a table (not geometries, they work as expected),
I get an error saying:
Interrogazione errata: SELECT
has_table_privilege('"myschema"."mytable"','DELETE'),has_any_column_privilege('"myschema"."mytable"','UPDATE'),has_column_privilege('"myschema"."mytable"','','UPDATE'),has_table_privilege('"myschema"."mytable"','INSERT'),current_schema()
ha restituito 7 [ERROR:  column "" of relation "mytable" does not exist
Impossibile determinare i privilegi di accesso alla tabella
Questo รจ l'errore riportato dal database:
SQL: SELECT
With all the geometric tables in the same schema there isn't any problem,
why?
Thanks
Pietro
View this message in context: http://osgeo-org.1560.x6.nabble.com/DB-manager-don-t-load-postgis-tables-not-geometric-tables-tp5088765.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
