[Qgis-user] Create a table of unique values with counts for a field?
Carlos López PSIG
carlos.lopez at psig.es
Wed Nov 13 07:18:16 PST 2013
You must entry USE field in Row column and Value column, and then entry
"Count" in the "Columns" column.
Luck,
* <http://www.psig.es> *
*Carlos López Quintanilla*
www.psig.es
+34 699.680.261
2013/11/13 Chrest, David <davidc at rti.org>
> I tried Group Stats and for the life of me could not get it to work. I
> have an airports layer with 75 points and 4 types in the USE field. I want
> a simple table listing the 4 types of airport uses in 4 records, then a
> count column giving me a count of each use type. In the Group Stats plugin,
> I put the Use field in Rows and the count function in value. The Calculate
> button is grayed out and I can’t do anything. I tried different
> combinations and nothing worked. Not sure what to put in the Columns box.
> Everything I tried still gave me a grayed, unusable Calculate button. Anita
> Graser’s tutorial at
> http://anitagraser.com/2013/02/02/group-stats-tutorial/ just shows two
> examples that are nothing like what I am trying to do. What exactly am I
> doing wrong?
> *From:* carlos.psig at gmail.com [mailto:carlos.psig at gmail.com] *On Behalf
> Of *Carlos López PSIG
> *Sent:* Wednesday, November 13, 2013 9:55 AM
> *To:* Chrest, David
> *Cc:* List QGIS user
> *Subject:* Re: [Qgis-user] Create a table of unique values with counts
> for a field?
> Hi David,
> You can use the "Group Stats" plugin.
> Regards,
> * <http://www.psig.es>*
> www.psig.es
> +34 699.680.261
> Is there a straightforward way to create a frequency table of a field? To
> get a list of all the unique values and the counts for each of those unique
> values for a field in a table, attribute table?
> David Chrest
> Research GIS Analyst
> RTI International
> 3040 Cornwallis Rd, PO Box 12194
> Research Triangle Park, NC 27709-2194
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131113/cb323462/attachment.html>
