[Qgis-user] Create a table of unique values with counts for a field?
Chrest, David davidc at rti.org
Wed Nov 13 07:25:06 PST 2013
Ah, yes. There it is. Works lovely. Very handy, I do this frequently. Man, I have been using ESRI software way too long. Thanks so much, Carlos.
David
From: carlos.psig at gmail.com [mailto:carlos.psig at gmail.com] On Behalf Of Carlos López PSIG
Sent: Wednesday, November 13, 2013 10:18 AM
To: Chrest, David
Cc: List QGIS user
Subject: Re: [Qgis-user] Create a table of unique values with counts for a field?
You must entry USE field in Row column and Value column, and then entry "Count" in the "Columns" column.
Luck,
 <http://www.psig.es>
Carlos López Quintanilla
www.psig.es
carlos.lopez at psig.es <mailto:carlos.lopez at psig.es>
+34 699.680.261
2013/11/13 Chrest, David <davidc at rti.org>
I tried Group Stats and for the life of me could not get it to work. I have an airports layer with 75 points and 4 types in the USE field. I want a simple table listing the 4 types of airport uses in 4 records, then a count column giving me a count of each use type. In the Group Stats plugin, I put the Use field in Rows and the count function in value. The Calculate button is grayed out and I can't do anything. I tried different combinations and nothing worked. Not sure what to put in the Columns box. Everything I tried still gave me a grayed, unusable Calculate button. Anita Graser's tutorial at http://anitagraser.com/2013/02/02/group-stats-tutorial/ just shows two examples that are nothing like what I am trying to do. What exactly am I doing wrong?
Sent: Wednesday, November 13, 2013 9:55 AM
To: Chrest, David
Cc: List QGIS user
Hi David,
You can use the "Group Stats" plugin.
Regards,
www.psig.es
+34 699.680.261 <tel:%2B34%20699.680.261>
Is there a straightforward way to create a frequency table of a field? To get a list of all the unique values and the counts for each of those unique values for a field in a table, attribute table?
David Chrest
Research GIS Analyst
RTI International
3040 Cornwallis Rd, PO Box 12194
Research Triangle Park, NC  27709-2194
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131113/650fb01e/attachment.html>
