[Qgis-user] Shape file points not appearing in 2.0.1
    Andreas Neumann
    a.neumann at carto.net
    Tue Nov 19 12:23:06 PST 2013
Hi Daniel,
Can you share this particular shapefile and the corresponding qml that
shows the problem?
Did you try to load it into a fresh project, not re-using the old
project? Can you load into an empty project?
Andreas
Am 19.11.2013 19:02, schrieb Daniel Kranich:
> Hello,
> I have been using Qgis for about a year and a half now. I just upgraded
> from 1.8 to 2.0 and have run into an issue with one of my shape files.
> I have a shape file that is a point layer which has been working fine
> and displaying fine in 1.8. When I open the layer in 2.0.1, The symbols
> no longer appear on the map. The attribute table still has all the data,
> and If I select one and pan the map to that selection, It zooms in to
> where that particular point should be but the point is not visible on
> the map.
> I have checked out the symbology and there is no reason for the points
> to not show up (checked transparency/size etc). I also tried removing
> the layer, and re-adding it and the same problem occurs. I have also
> double checked that it is the top layer and should be rendered on top of
> everything else, and I double checked the Coordinate system. Somehow the
> points are there, and when you go to a specific point, it takes you to
> the right place, but the point just isn't appearing on the map.
> Has anyone else encountered a problem similar to this? I searched a bit
> through the bug tracker, but found nothing. Im also planning on moving
> all our data over to a PostGIS database and hopefully this might fix the
> problem, but until then I would really rather use 2.0 instead of 1.8.
> Thanks.
> Qgis-user mailing list
