[Qgis-user] Qgis working or dead?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Nov 20 03:57:32 PST 2013
On 20 November 2013 10:45, Alexandre Neto <senhor.neto at gmail.com> wrote:
>> Well you've got a point even one could turn it upside down and argue that
>> a
>> living creature should be able to tell it is alive? ;-)
> You can do that, take a look into you task manager, If it's using CPU,
> then it's ALIVE!
It could be in an infinite loop. Over the years I've had countless
applications crash while using 100% of a Core.
Ideally QGIS could poll itself to see if it is alive. No idea if that could
be done, but it'd be useful as a user.
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/319df31e/attachment.html>
