[Qgis-user] network building tool
Brent Fraser bfraser at geoanalytic.com
Wed Nov 20 14:35:11 PST 2013
Tim,
   I've used a relational database with a table of nodes (with lat, lon)
and a table of connections (from_node, to_node), then created a view to
represent lines in well-known-text.  Move a node and all the lines would
move along with it since they're defined as a view.   The line movement
was not dynamic; it would require a pan/zoom/refresh in the web app as
the graphics were rendered on the server (via Mapserver).
Best Regards,
Brent Fraser
On 11/20/2013 2:38 PM, Tim Michelsen wrote:
>>    Graphviz (http://www.graphviz.org/) will do most of what you
>> described, but I don't think you can specify the coordinates of the
>> nodes (that would be nice) so the result is just a diagram, not a map .
> Not exactly.
> Via
> Representation of network flows /
> http://gis.stackexchange.com/questions/778/representation-of-network-flows
> I found JFlowMap.
> It uses the approach I described:
> https://code.google.com/p/jflowmap/wiki/HowToPrepareData
> I just don't know if it can also export to shape...
> [question off-list:]
>> do you mean something that just draw the lines or that will
> create/manage actual line features?
> A line drawing tool which would allow to maintain connections of lines
> if nodes are shifted.
> The background for all is that the simlation and design tools for
> networks can export lines (e.g. power lines, telecom lines) or nodes as
> lists but no logical structure.
> A typical schema:
> http://en.wikipedia.org/wiki/File:Electricity_Grid_Schematic_English.svg
> http://en.wikipedia.org/wiki/File:One-line_diagram.svg
> So I wonder how others are transferring such information into the
> GIS/geo domain.
> Regards,
> Timmie
> Qgis-user mailing list
