[Qgis-user] network building tool
Tim Michelsen timmichelsen at gmx-topmail.de
Thu Nov 21 00:46:57 PST 2013
> Have you given a look at FlowMapper plugin?
http://plugins.qgis.org/plugins/FlowMapper/
The issue with flowmap is that it's designed for a limited number of flows:
* the matrix must always have the same dimensions as the listed nodes
* the order of matrix and nodes must be the same
* even if is set the flow volume to 1, focus is on the flow and not the line
type
