[Qgis-user] network building tool
G. Allegri
giohappy at gmail.com
Wed Nov 20 14:28:35 PST 2013
Have you given a look at FlowMapper plugin?
http://plugins.qgis.org/plugins/FlowMapper/
Here you can find an example, without using the plugin but only a PostGIS
layer.
giovanni
Il 20/nov/2013 22:39 "Tim Michelsen" <timmichelsen at gmx-topmail.de> ha
scritto:
> > Graphviz (http://www.graphviz.org/) will do most of what you
> > described, but I don't think you can specify the coordinates of the
> > nodes (that would be nice) so the result is just a diagram, not a map .
> Not exactly.
> Via
> Representation of network flows /
> http://gis.stackexchange.com/questions/778/representation-of-network-flows
> I found JFlowMap.
> It uses the approach I described:
> https://code.google.com/p/jflowmap/wiki/HowToPrepareData
> I just don't know if it can also export to shape...
> [question off-list:]
> > do you mean something that just draw the lines or that will
> create/manage actual line features?
> A line drawing tool which would allow to maintain connections of lines
> if nodes are shifted.
> The background for all is that the simlation and design tools for
> networks can export lines (e.g. power lines, telecom lines) or nodes as
> lists but no logical structure.
> A typical schema:
> http://en.wikipedia.org/wiki/File:Electricity_Grid_Schematic_English.svg
> http://en.wikipedia.org/wiki/File:One-line_diagram.svg
> So I wonder how others are transferring such information into the
> GIS/geo domain.
> Regards,
> Timmie
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131120/451b6e26/attachment.html>
