[Qgis-user] Using GRASS through Processing
    William Kyngesburye
    woklist at kyngchaos.com
    Wed Nov 20 17:26:59 PST 2013
What system version are you on?
To check the execute setting, in a Terminal type:
    ls -la /Applications/QGIS.app/Contents/MacOS/grass/
the first part of the line for grass.sh should read "-rwxr-xr-x@".  If there are not 3 x's in there, you can fix it with (again in a terminal):
    sudo chmod +x /Applications/QGIS.app/Contents/MacOS/grass/grass.sh
On Nov 20, 2013, at 5:39 PM, Mark Seibel wrote:
> Hi.
> > I took a look at the INFO in Processing and I got this message
> > GRASS execution console output
> > /bin/sh: /Applications/QGIS.app/Contents/MacOS/grass/grass.sh: Permission denied
> > How can I have access to GRASS to Processing?
> Is this file " /Applications/QGIS.app/Contents/MacOS/grass/grass.sh" set to executable?
> Mark
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed robot?
[Marvin]  You think you have problems?  What are you supposed to do if you ARE a maniacally depressed robot?  No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
