[Qgis-user] Using GRASS through Processing
Manuel Spínola
mspinola10 at gmail.com
Thu Nov 21 05:37:41 PST 2013
Thank you very much.
This is what I got:
Last login: Thu Nov 21 07:30:34 on console
MacBook-Pro-de-Manuel:~ manuelspinola$ ls -la
/Applications/QGIS.app/Contents/MacOS/grass/
total 8
drwxrwxr-x 12 root admin 408 Oct 30 11:11 .
drwxrwxr-x 7 root admin 238 Oct 30 11:11 ..
drwxrwxr-x 327 root admin 11118 Oct 30 11:11 bin
drwxrwxr-x 44 root admin 1496 Oct 30 11:11 bwidget
drwxrwxr-x 3 root admin 102 Aug 3 10:25 docs
drwxrwxr-x 8 root admin 272 Oct 30 11:11 driver
drwxrwxr-x 85 root admin 2890 Oct 30 11:11 etc
drwxrwxr-x 25 root admin 850 Oct 30 11:11 fonts
-rw-r--r-- 1 root admin 3074 Sep 7 09:12 grass.sh
drwxrwxr-x 110 root admin 3740 Oct 30 11:11 lib
drwxrwxr-x 88 root admin 2992 Oct 30 11:11 scripts
drwxrwxr-x 5 root admin 170 Oct 30 11:11 tools
2013/11/20 William Kyngesburye <woklist at kyngchaos.com>
> What system version are you on?
> To check the execute setting, in a Terminal type:
> ls -la /Applications/QGIS.app/Contents/MacOS/grass/
> the first part of the line for grass.sh should read "-rwxr-xr-x@". If
> there are not 3 x's in there, you can fix it with (again in a terminal):
> sudo chmod +x /Applications/QGIS.app/Contents/MacOS/grass/grass.sh
> On Nov 20, 2013, at 5:39 PM, Mark Seibel wrote:
> > Hi.
> > > I took a look at the INFO in Processing and I got this message
> > > GRASS execution console output
> > > /bin/sh: /Applications/QGIS.app/Contents/MacOS/grass/grass.sh:
> Permission denied
> Permission denied
> > > How can I have access to GRASS to Processing?
> > Is this file " /Applications/QGIS.app/Contents/MacOS/grass/grass.sh" set
> to executable?
> > Mark
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> [Trillian] What are you supposed to do WITH a maniacally depressed robot?
> [Marvin] You think you have problems? What are you supposed to do if you
> ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000
> times more intelligent than you and even I don't know the answer...
> - HitchHiker's Guide to the Galaxy
*Manuel Spínola, Ph.D.*
Instituto Internacional en Conservación y Manejo de Vida Silvestre
Universidad Nacional
Apartado 1350-3000
Heredia
COSTA RICA
mspinola at una.ac.cr
Teléfono: (506) 2277-3598
Fax: (506) 2237-7036
Personal website: Lobito de río <https://sites.google.com/site/lobitoderio/>
Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/bb0497ca/attachment.html>
