[Qgis-user] Export a raster to Esri's standard Ascii Grid format
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Nov 21 01:54:37 PST 2013
Hi Rob,
>From the main menu, Raster > Conversion > Translate (Convert formats)
A new window appears
Click Select for Output.
In the new window, under File of types, click on the drop-down menu and
select [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
<http://www.lutraconsulting.co.uk/> www.lutraconsulting.co.uk
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Rob Stewart
Sent: 21 November 2013 09:50
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Export a raster to Esri's standard Ascii Grid format
I'm new to QGIS (long time mapinfo user) - Is it possible to export a raster
to Esri's standard Ascii Grid format?
I'm using QGIS 2.0.1 on a Windows 7 64bit system.
Thanks,
Rob
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/212b60b3/attachment.html>
