[Qgis-user] Export a raster to Esri's standard Ascii Grid format
Rob Stewart
rstewart at hydrologyandwater.com.au
Thu Nov 21 03:02:37 PST 2013
Thanks Saber,
That seemed to be what I was after but when I exported the Raster to
Arc/Info ASCII Grid format it created a *asc file in a non-text format
which isn't what I was expecting. Seems strange - any ideas?
On 21 November 2013 19:54, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi Rob,
> From the main menu, Raster > Conversion > Translate (Convert formats)
> A new window appears
> Click Select for Output.
> In the new window, under File of types, click on the drop-down menu and
> select [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
> Cheers,
> Saber
> Saber Razmjooei
> *Lutra Consulting*
> www.lutraconsulting.co.uk
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Rob Stewart
> *Sent:* 21 November 2013 09:50
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Export a raster to Esri's standard Ascii Grid
> format
> Hi,
> I'm new to QGIS (long time mapinfo user) - Is it possible to export a
> raster to Esri's standard Ascii Grid format?
> I'm using QGIS 2.0.1 on a Windows 7 64bit system.
> Thanks,
> Rob
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/4508beb9/attachment.html>
