[Qgis-user] Export a raster to Esri's standard Ascii Grid format
    Werner Macho
    werner.macho at gmail.com
    Thu Nov 21 03:09:57 PST 2013
IIRC there is a bug where you have to correct the command line manually before running it..
Per default it always creates tiff files (that's why it is a binary file)
Hth
Regards Werner
Rob Stewart <rstewart at hydrologyandwater.com.au> wrote:
>Thanks Saber,
>That seemed to be what I was after but when I exported the Raster to
>Arc/Info ASCII Grid format it created a *asc file in a non-text format
>which isn't what I was expecting.  Seems strange - any ideas?
>On 21 November 2013 19:54, Saber Razmjooei <
>saber.razmjooei at lutraconsulting.co.uk> wrote:
>> Hi Rob,
>> From the main menu, Raster > Conversion > Translate (Convert formats)
>> A new window appears
>> Click Select for Output.
>> In the new window, under File of types, click on the drop-down menu
>and
>> select [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
>> Cheers,
>> Saber
>> Saber Razmjooei
>> *Lutra Consulting*
>> www.lutraconsulting.co.uk
>> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
>> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Rob Stewart
>> *Sent:* 21 November 2013 09:50
>> *To:* qgis-user at lists.osgeo.org
>> *Subject:* [Qgis-user] Export a raster to Esri's standard Ascii Grid
>> format
>> Hi,
>> I'm new to QGIS (long time mapinfo user) - Is it possible to export a
>> raster to Esri's standard Ascii Grid format?
>> I'm using QGIS 2.0.1 on a Windows 7 64bit system.
>> Thanks,
>> Rob
>> This email and any files transmitted with it are confidential and
>intended
>> solely for the use of the individual or entity to whom they are
>addressed.
>> If you have received this email in error please notify the system
>manager.
>> This message contains confidential information and is intended only
>for the
>> individual named. If you are not the named addressee you should not
>> disseminate, distribute or copy this e-mail. Please notify the sender
>> immediately by e-mail if you have received this e-mail by mistake and
>> delete this e-mail from your system. If you are not the intended
>recipient
>> you are notified that disclosing, copying, distributing or taking any
>> action in reliance on the contents of this information is strictly
>> prohibited.
>> Whilst reasonable care has been taken to avoid virus transmission, no
>> responsibility for viruses is taken and it is your responsibility to
>carry
>> out such checks as you feel appropriate.
>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/aac9abe1/attachment.html>
