[Qgis-user] Export a raster to Esri's standard Ascii Grid format
Rob Stewart
rstewart at hydrologyandwater.com.au
Thu Nov 21 03:18:29 PST 2013
Thanks Werner - Yep that fixed it. I manually put in 'aaigrid' in the
command line and it produced the correct file type.
Rob
On 21 November 2013 21:09, Werner Macho <werner.macho at gmail.com> wrote:
> IIRC there is a bug where you have to correct the command line manually
> before running it..
> Per default it always creates tiff files (that's why it is a binary file)
> Hth
> Regards Werner
> Rob Stewart <rstewart at hydrologyandwater.com.au> wrote:
>> Thanks Saber,
>> That seemed to be what I was after but when I exported the Raster to
>> Arc/Info ASCII Grid format it created a *asc file in a non-text format
>> which isn't what I was expecting. Seems strange - any ideas?
>> On 21 November 2013 19:54, Saber Razmjooei <
>> saber.razmjooei at lutraconsulting.co.uk> wrote:
>>> Hi Rob,
>>> From the main menu, Raster > Conversion > Translate (Convert formats)
>>> A new window appears
>>> Click Select for Output.
>>> In the new window, under File of types, click on the drop-down menu and
>>> select [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
>>> Cheers,
>>> Saber
>>> Saber Razmjooei
>>> *Lutra Consulting*
>>> www.lutraconsulting.co.uk
>>> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
>>> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Rob Stewart
>>> *Sent:* 21 November 2013 09:50
>>> *To:* qgis-user at lists.osgeo.org
>>> *Subject:* [Qgis-user] Export a raster to Esri's standard Ascii Grid
>>> format
>>> Hi,
>>> I'm new to QGIS (long time mapinfo user) - Is it possible to export a
>>> raster to Esri's standard Ascii Grid format?
>>> I'm using QGIS 2.0.1 on a Windows 7 64bit system.
>>> Thanks,
>>> Rob
>>> This email and any files transmitted with it are confidential and
>>> intended solely for the use of the individual or entity to whom they are
>>> addressed. If you have received this email in error please notify the
>>> system manager. This message contains confidential information and is
>>> intended only for the individual named. If you are not the named addressee
>>> you should not disseminate, distribute or copy this e-mail. Please notify
>>> the sender immediately by e-mail if you have received this e-mail by
>>> mistake and delete this e-mail from your system. If you are not the
>>> intended recipient you are notified that disclosing, copying, distributing
>>> or taking any action in reliance on the contents of this information is
>>> strictly prohibited.
>>> Whilst reasonable care has been taken to avoid virus transmission, no
>>> responsibility for viruses is taken and it is your responsibility to carry
>>> out such checks as you feel appropriate.
>>> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/ca1e6a88/attachment.html>
