[Qgis-user] Export a raster to Esri's standard Ascii Grid format
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Nov 21 03:19:33 PST 2013
That’s right Werner. Thanks for the hint. I was using QGIS dev and it worked fine!
Cheers,
Saber
From: Werner Macho [mailto:werner.macho at gmail.com]
Sent: 21 November 2013 11:10
To: Rob Stewart; Saber Razmjooei
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Export a raster to Esri's standard Ascii Grid format
IIRC there is a bug where you have to correct the command line manually before running it..
Per default it always creates tiff files (that's why it is a binary file)
Hth
Regards Werner
Rob Stewart <rstewart at hydrologyandwater.com.au> wrote:
Thanks Saber,
That seemed to be what I was after but when I exported the Raster to Arc/Info ASCII Grid format it created a *asc file in a non-text format which isn't what I was expecting. Seems strange - any ideas?
On 21 November 2013 19:54, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk> wrote:
Hi Rob,
>From the main menu, Raster > Conversion > Translate (Convert formats)
A new window appears
Click Select for Output.
In the new window, under File of types, click on the drop-down menu and select [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Rob Stewart
Sent: 21 November 2013 09:50
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Export a raster to Esri's standard Ascii Grid format
I'm new to QGIS (long time mapinfo user) - Is it possible to export a raster to Esri's standard Ascii Grid format?
I'm using QGIS 2.0.1 on a Windows 7 64bit system.
Thanks,
Rob
_____
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
_____
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/fbc4d2fc/attachment.html>
