[Qgis-user] Export a raster to Esri's standard Ascii Grid format
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Thu Nov 21 03:10:50 PST 2013
Very strange indeed. Just converted one and it appears fine.
Are you sure you picked  [GDAL] Arc/Info ASCII Grid and not [GDAL] Arc/Info
Binary Grid?
Cheers,
Saber
From: Rob Stewart [mailto:rstewart at hydrologyandwater.com.au]
Sent: 21 November 2013 11:03
To: Saber Razmjooei
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Export a raster to Esri's standard Ascii Grid
format
Thanks Saber,
That seemed to be what I was after but when I exported the Raster to
Arc/Info ASCII Grid format it created a *asc file in a non-text format which
isn't what I was expecting.  Seems strange - any ideas?
On 21 November 2013 19:54, Saber Razmjooei
<saber.razmjooei at lutraconsulting.co.uk> wrote:
Hi Rob,
>From the main menu, Raster > Conversion > Translate (Convert formats)
A new window appears
Click Select for Output.
In the new window, under File of types, click on the drop-down menu and
select [GDAL] Arc/Info ASCII Grid (*.asc *.ASC).
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Rob Stewart
Sent: 21 November 2013 09:50
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Export a raster to Esri's standard Ascii Grid format
I'm new to QGIS (long time mapinfo user) - Is it possible to export a raster
to Esri's standard Ascii Grid format?
I'm using QGIS 2.0.1 on a Windows 7 64bit system.
Thanks,
Rob
  _____
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager.
This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail. Please notify the sender
immediately by e-mail if you have received this e-mail by mistake and delete
this e-mail from your system. If you are not the intended recipient you are
notified that disclosing, copying, distributing or taking any action in
reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no
responsibility for viruses is taken and it is your responsibility to carry
out such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131121/aef58daf/attachment.html>
