[Qgis-user] Shape file points not appearing in 2.0.1
Eureka Modélisation
ismael.bernard at eureka-model.com
Thu Nov 21 04:00:02 PST 2013
Hi all,
I follow this thread with interest because I have a layer with exactly
the same behaviour, behaviour which also appear in the transition from
QGIS 1.8 to 2.0.
Unfortunately, I don't find any point with all NULL attributes in this
layer.
You can find the layer here : https://db.tt/1kPuqEvd (a bit big, sory !)
Thanks for any help
Ismaël
On 20/11/2013 01:51, Daniel Kranich wrote:
> Well It looks like I solved my own problem. I went in and found that
> there was a point with NULL in all the attribute fields, so I deleted
> that point and saved the file and everything shows up now.
> Weird.
> Daniel.
> On 11/19/2013 3:25 PM, Daniel Kranich wrote:
>> oops... I don't use mailing lists often so Its not surprising.
>> I know that "Rangeview" does not have any attributes and the ID's are
>> null, but it was simply meant to be used for visual purposes on the
>> map and not meant to have any data associated with it.
>> I will go ahead and file a bug report. In the mean time I guess I'm
>> stuck with 1.8 :(
>> Daniel
>> On 11/19/2013 1:16 PM, Andreas Neumann wrote:
>>> Hi Daniel,
>>> It seems you answered only me personal and forgot to post this
>>> information to the list.
>>> I can confirm the strange behaviour on both QGIS 2.0 and QGIS master.
>>> You should open a bug report.
>>> I can open both files in FME, but "Rangeview" does not contain any
>>> attributes and all the ids are NULL values.
>>> Andreas
>>> Am 19.11.2013 21:56, schrieb Daniel Kranich:
>>>> Well I have done a lot more troubleshooting. here is what I found:
>>>> -It seems that it is only this particular shapefile.
>>>> -I can see the points if I am zoomed out far enough, but as I zoom in,
>>>> they disappear.
>>>> -When zoomed out far enough to see them, I am unable to select them
>>>> using the rectangle select tool
>>>> -This is the case even if I load it into a new project.
>>>> -If I select a specific point in the attribute table and hit the "zoom
>>>> to selected rows" button, it seems to take me to the correct place,
>>>> however the points don't appear.
>>>> -There are a few points that actually DO appear.
>>>> -ALL the points appear at ALL zoom levels in 1.8
>>>> -I have tried messing with the "Scale Dependent Rendering" and that
>>>> changes nothing.
>>>> Here are some screenshots:
>>>> The points on the far upper right are the ones I would like to
>>>> see/manipulate: http://prntscr.com/25apve
>>>> After zooming in: http://prntscr.com/25aqic
>>>> Here is a link to download two shape files. "Water Nodes" is the one
>>>> that is a problem. the "Rangeview" shape file is there as reference
>>>> for
>>>> the general area where some of the Water Nodes should be appearing.
>>>> Both
>>>> are set to EPSG:26934 - NAD83 / Alaska zone 4 coordinate system:
>>>> http://www.mediafire.com/download/l8nhd1xzmg3v6z2/WaterNodes.zip
>>>> Thanks for the help
>>>> On 11/19/2013 11:23 AM, Andreas Neumann wrote:
>>>>> Hi Daniel,
>>>>> Can you share this particular shapefile and the corresponding qml
>>>>> that
>>>>> shows the problem?
>>>>> Did you try to load it into a fresh project, not re-using the old
>>>>> project? Can you load into an empty project?
>>>>> Andreas
>>>>> Am 19.11.2013 19:02, schrieb Daniel Kranich:
>>>>>> Hello,
>>>>>> I have been using Qgis for about a year and a half now. I just
>>>>>> upgraded
>>>>>> from 1.8 to 2.0 and have run into an issue with one of my shape
>>>>>> files.
>>>>>> I have a shape file that is a point layer which has been working
>>>>>> fine
>>>>>> and displaying fine in 1.8. When I open the layer in 2.0.1, The
>>>>>> symbols
>>>>>> no longer appear on the map. The attribute table still has all
>>>>>> the data,
>>>>>> and If I select one and pan the map to that selection, It zooms
>>>>>> in to
>>>>>> where that particular point should be but the point is not
>>>>>> visible on
>>>>>> the map.
>>>>>> I have checked out the symbology and there is no reason for the
>>>>>> points
>>>>>> to not show up (checked transparency/size etc). I also tried
>>>>>> removing
>>>>>> the layer, and re-adding it and the same problem occurs. I have also
>>>>>> double checked that it is the top layer and should be rendered on
>>>>>> top of
>>>>>> everything else, and I double checked the Coordinate system.
>>>>>> Somehow the
>>>>>> points are there, and when you go to a specific point, it takes
>>>>>> you to
>>>>>> the right place, but the point just isn't appearing on the map.
>>>>>> Has anyone else encountered a problem similar to this? I searched
>>>>>> a bit
>>>>>> through the bug tracker, but found nothing. Im also planning on
>>>>>> moving
>>>>>> all our data over to a PostGIS database and hopefully this might
>>>>>> fix the
>>>>>> problem, but until then I would really rather use 2.0 instead of
>>>>>> 1.8.
>>>>>> Thanks.
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
